Joining walls
Tool |
Tool set |
Wall Join
Building Shell |
The Wall Join tool joins straight or curved wall segments and their components. There are three modes for joining walls and two end cap modes.
Mode |
Description |
T Join
Lengthens or shortens one wall segment until it intersects with the second wall segment selected; creates Y joins by joining the first selected wall to two sections of an existing L join |
L Join
Joins the closest ends of two walls to create a corner |
X Join
Joins two wall segments at the point where they intersect |
Uncapped Join
Applies an uncapped join to wall join operations |
Capped Join
Applies a capped join to wall join operations |
To temporarily activate this tool, right-click on a wall, and select Join from the context menu. The tool defaults to the mode used previously with the tool.
